Cranks But No Start
radicaltoy
I am working on a 2006 GMC sierra with a 4.3L has 50000 miles. I am getting plenty of fuel but no fire at the coil. Tested the IC timing control from PCM to ICM with dmm ac volts had 4 volts. Tested ground to IC module with test light to B+ test light illuminated ground was ok. Tested Ign 1 voltage from fuse box to ICM w/ test light light illuminated. Tested Ign coil control from ICM to Coil with test light to B+ light blinked but was dim. Tested Ign 1 voltage from fuse box to coil had 12.2 volts.Coil has been replaced still no fire. Has new crank sensor Any help would be greatly appretiated
    mighty K20
    mighty K20
  • Who's Online   3 Members, 1 Anonymous, 621 Guests (See full list)
