VIN numbers
NewbieZ71
I understand some of what the VIN number tells you but I don't know most of it. I know the 8th character is the engine code. 10th is the year and 11th is the assembly plant.my assembly plant is "1". I think it is in Canada but I'm not sure. Can I tell from this number my assembly date?
OK. Time to pay back for all the help you guys give me.
Bear with me. The way my manual breaks it down is pretty long. This is from a 2000 Silverado/Sierra/Tahoe/Yukon........manual... Well, you get the picture.
Position 1 - Country of origin - 1 US, 2 Canada, 3 Mexico
Pos2 - Manufacturer - G - General Motors
Pos3 - Make - B Chevrolet, C Incomplete Chevrolet Truck, D GMC, T Incomplete GMC Truck
Pos4 - GVWR/Brake System - E 6001-7000/Hydraulic, F 7001-8000/Hydraulic, G 8001-9000/Hydraulic, H 9001-10000/Hydraulic
Pos 5 - Truck line/Chassis Type - C Conventional Cab/4x2, K Conventional Cab/4x4
Pos 6 - Series - 1 Half ton, 2 Three Quarter ton
Pos 7 - Body type - 4 Regular Cab, 9 Extended Cab
Pos 8 - Engine Type - V (LR4) 4.8L Gas, U (LQ4) 6.0L Gas, T (LM7) 5.3L Gas, W (L35) 4.3L Gas
Pos 9 - Check Digit
Pos 10 - Model Year - Y 2000
Pos 11 - Plant Location - 1 Oshawa, Ontario, E Pontiac, Michigan, Z Fort Wayne, Indiana, G Silao, Mexico
Pos 12 - Plant Sequence Number -
Hope this isn't too confusing. Any questions, feel free to ask.
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 349 Guests (See full list)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
