Anyone Have Any Problems With A Ready Lift 2.25" Leveling Kit?
I'll be having one of these kits installed in my 2011 4X4 next week and have a couple of concerns. One is the new angle of the front half shafts. I have heard of Rams with similar leveling kits causing a wobble through the steering due to the angle. Also is it very likely I'll be able to get the alignment back to factory specs.
You will be fine, you can't compare one from a dodge to a chevy. I have a 2.5" on mine. A lot of people has the CCM with no problems.
One other thing, my truck came with the factory 20s and of course the Z60 suspension. It claims to be lower than a standard suspension truck so... does anyone know if a 2.25" front lift too much relative to the rear. The truck looks no different in height to me than any other truck on the Chevy lot when I bought it.
-Steve
I doubt it is any different (or at least you won't be able to tell). If for some reason it is, which I doubt, just add larger (maybe 2") blocks in the rear. I have 3" blocks and the CCM 2.5" leveling kit up front. I only have about .75" to 1" of rake now.
Good idea. I may want to do that anyway. I plan on putting a taller tire on it later but I don't want it to look too weird with the stock rubber. Thanks for help guys.
-Steve
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
