Trouble Starting And Losing Power
just picked up an 88 gmc 2500 with a 350 a couple weeks ago. I bought the truck as a project/toy/beater and haven't had much time to work on it. The truck is having a hard time getting started and once i get it running it loses power in lower rpms and wants to stall. I bought a new battery for it which i will be putting in this weekend but I have a feeling the problem runs deeper than just the battery for getting it started(not to mention the bogging issue). I have gotten the truck started on ether but it takes a few attempts and lots of patience. The truck does have an exhaust leak at the y pipe (exhaust is completely broken off at the end of the y) Is there enough back pressure for the exhaust with the y pipe broken? Let me know what you guys think. Thanks
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 641 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
