Increase My Towing Capacity?
cflgm
I posted a topic on Sunday in the Fullsize Truck section and have a follow up that seems more appropriate for here (sorry for the multiple topics).
I have an 09 Silverado Crew Cab with the 4.8L and 3.23 rear end. According to my OM, I can tow 4,700 lbs (max rig total of 10,000 lbs).
I am shopping for an offshore boat and would like to be able to pull up to 5,500 lbs. I checked w/ a couple local GM dealerships on a quote to swap to a 3.73 and they said I need the whole unit which is $3,700 for parts and $400 for labor. REALLY?
Does anyone know if this is true or if I can just swap the gear itself? I assume there would be some reprogramming needed...but that just seemed outrageous.
If a 3.73 is too big, is there an option for a 3.42?
And if a gear swap is not a good option, is there anything else I can do to get another 500 lbs of capacity?
I only have 30K miles on the truck, so I don't want to do anything that will void my warranty.
Thanks everyone!!
You can swap just the gears, find yourself a driveline shop in your area. The will be able to do it. What I don't know is what sort of programming is involved. But before you go doing all that, what kind of terrain and what sort of distance will you be traveling? If it is fairly flat and distance short I would be inclined to tow it first and see how it does.
Since you have the 4.8, I wouldn't do anything less than 4.10 gears. That will get you the most bang for the buck. If you take your truck to a good offroad shop, they should be able to do a gear sway for around $500 for a 2wd pickup and around $1500 for a 4wd. This would include the gears, master rebuild kit, and labor.
Next would be long tube headers and custom tune. Both will help with some extra grunt. :dunno: But in my opinion, the 4.10 gear swap will give you all you need. But regardless of what gears you pick, you'll need to have your ECM programmed for the new gears.
How far are you towing the boat, hills, etc? Payload/handling/braking will be the same, so you're really only talking power and stress on the drive-train. 500 lbs over would just mean pulling out even slower and driving easier. If you plan to tow longer distances or often, a gear swap and reprogram for the gears is the most bang per buck. I haven't had it done, but all $$ figures I've seen have been consistent with what Stephen stated.
I'd get the boat and see how it does before jumping too deep.
While I will not arque with Steven, His advice is spot on if you are going to do a lot of towing. I do still have to ask about distances and terrain, I used to pull 8k about 5 miles each way to the ramp with an S10, while I sure wouldn't do a 1200 mile tow with it, it did work great to launch and pull the boat about 3 times a year.
So, why void a 100k axle warranty and reduce gas mileage for something you do only 1% of the time?
I live in south FL (everything's flat and hot) and will be pulling it 10-50 miles (each way) at least 2x per month. Will probably do longer trips (300+ mi) a couple times per year.
I also need to consider my GVW since I'll likely have 4 adults in the truck + cargo (man, this adds up quick).
If I have a local shop swap the gear, will it void my entire powertrain 100k mi warranty? With only 30K on the truck now, that's not something I'm willing to do.
I dont see how the dealer would ever know unless your rear axel is what failed and they opened the diff to investigate. The new parts should be warrantied themselves so if thats the case, just take it to the shop that did the swap, not the dealer.
It should only void the warranty on axle. But if you go to 4.10s and that was not an option then it could be possible for GM to void the entire powertrain warranty. I would talk with the dealer and see what they say.
The dealer is going to knoiw because the computer is going to need to be reprogrammed for the gears.
I can tell you what the dealer is going to do. They are going to pull some hosreshit reason out of their ass as to why the gears would void any and all warranties. Even though, in this instance it makes a little sense that this mod would affect the powertrain somewhat. I guarantee they will make some sort of remark like, "Theres a reason that ratio wasnt offered with that package". They will look for any reason to squirm out of warranty work. I guess they make more money if its coming out of your pocket as opposed to coming from GM. I dont care much for dealerships. Ive found that people at deaperships are totally clueless or crooked, or both (most of the time, not all).
Ive had some bad experiences with dealerships. Can you tell? :dunno:
Just changing the rear end ratio is not the only thing you need to consider. Just a few others, tranny cooler, engine oil cooler, tongue weight. Don't forget to add the weight of your trailer and the fuel and other stuff you load the boat with. Going to the local ramp, better hope it's not too steep, is not the same as towing 300 miles in Florida in August. My opinion, is you need a different truck or a smaller boat.
I am shopping for an offshore boat and would like to be able to pull up to 5,500 lbs. I checked w/ a couple local GM dealerships on a quote to swap to a 3.73 and they said I need the whole unit which is $3,700 for parts and $400 for labor. REALLY? Does anyone know if this is true or if I can just swap the gear itself? I assume there would be some reprogramming needed...but that just seemed outrageous.
Thanks everyone!!
Isn't the 3.73 gear set only a G80 Locker? If so, this would probably be the reason for having to change the whole unit. Also, since the whole truck is still under warranty, they probably would have to remove an entire "option" and install another entire "option" to keep the warranty intact.
I have the same setup.I tow about 5000lbs once a week on a 400 mile round trip.Pulls and stops fine. Of course it will slow you down on hills.I am having a lighter smaller trailer built now just to help my loads.I would not hesitate to pull what you are talking about short distances.Of course I drive under the speed limit and always aware of my surroundings.(Mainly other nuts on the road).
I have 3.73 gears and no G80 locker.
    • New to this forum.  Also looking to tune a 6L80 and trying to work out all the issues in my transmission swap.  I have a 6.2 diesel (1983) and have removed the TH-400 and about to put in a 6L80 with a TCM-2600 interface and don't have a clue what I doing after that.  Did you (Leatherneck/RAV3) get your slip resolved? I too hate to spend that kind of money on a tuner that hopefully I will not need too many times although from what steelerdude15 added about the HP Tuner being great for diagnostics would be a plus.  I am also from WNC but below you in Columbus.  Any helo would be greatly appreciated.
    • Sounds like a smart reasonable person with common sense. Bill O’Riley never said he was just a journalist, by the way.
    • It's like saying Bill O'Reilly is "just" a journalist.         Lauren Fix, widely known as "The Car Coach," is a prominent automotive journalist, television personality, and self-identified conservative. She is a frequent contributor to right-leaning networks and platforms, offering commentary that intersects the automotive industry, consumer economics, and conservative political perspectives. [1, 2, 3] Media and Commentary Network Contributions: Fix serves as the National Automotive Correspondent for Newsmax and is a frequent guest on Fox News and Fox Business. Video Platforms: She has contributed to PragerU, where she has hosted videos critiquing government mandates on vehicles. [1, 2, 3] Core Positions Anti-EV Mandates & Fuel Policies: Fix regularly critiques government subsidies and mandates for electric vehicles (EVs), framing them as impractical and burdensome to the average consumer. She advocates for consumer choice and supports traditional internal combustion engine vehicles. [1, 2, 3] Economic Analysis: Her commentary often emphasizes the impacts of fuel prices, inflation, and federal regulations on drivers. [1, 2, 3] Political Alignment: On her public channels, she actively supports deregulation, "drill baby drill" energy policies, and the removal of government restrictions on auto sales and manufacturing. [1, 2] For analysis from Lauren Fix on how consumer automotive choices can align with political leanings:
    • Wouldn't swapping out the original AFM/DFM parts for a complete Delete Kit be the best route to go if one could afford to go that route?
    • It comes with directions but yes, generally, it's the same.  Also, get you the dipstick stuff to install dipstick so you have one.
