Vibration Problem After New Tires
marine_devildog801
I just replaced my Nitto TG's with Mickey Thompson ATZ's same size (285/70/17). After they were balanced and installed I started to feel a subtle vibration at low speeds. To be exact, the vibration is in about the 5mph window. While braking and after take-off. I can feel it in my seat and it feels/sounds like it is coming from the rear of the truck. It doesn't shake the truck, but it is a high frequency subtle vibration. Kind of a "deeper" tone if you will. No other vibrations at high speeds or at any other speeds (while braking or not). I took it back to the tire shop and had them drive it. They felt the same thing, but had no idea what it could be. Before I take it to the dealer I want to know if anyone has had any experience with this problem...if it is a problem. I have read a few things I found via Google that suggest it might be a problem with the driveshaft/u-joints being out balance?? I got under my truck and checked for play in the driveshaft, but found none. It has never happened until I got the tires put on. Truck has right at 40,000 miles. Any help is greatly appreciated.
My truck is an '07 1500 Extended Cab with a 2" leveling kit, 17x9 aftermarket wheels, and 285/70/17 tires.
No... its the aftermarket wheels.
The aftermarket wheels don't have chamfers on the back side for the retaining clips that are put on from the factory to hold the rotors in place on the assembly line... this results in exactly what the OP is describing.
Take your wheels off, remove all of the clips that are around the wheel studs (diagonal cutters does a good job), put the wheels back on, torque, and you're good to go.
aaaaaahhh yeah, if they're the same wheels that he had on there previously then its probably not them.
We see these types of posts so often that i may have jumped the gun as soon as i saw his last line where he mentioned aftermarket wheels :P
I have had the wheels for 3 years so it can't be them. I read about that trying to figure out my problem though. Thanks.
govtech - I read up that it might be because of the agressive tread "thumping" at low speeds? Is that what you mean or might it be a balance issue?
Matt - You had these tires. Did yours thump at low speeds?
I did not have that issue with mine... they were smooth.
You said its predominantly the rear? Rotate them to see if the noise/vibe moves to the front.
out of balance is if i convert properly is 80 km hr which is 50 mph??
low speed is always tires thumping complaining ,
+1 on Matt ^^^^
    bellssn690
    bellssn690
  • Who's Online   4 Members, 1 Anonymous, 544 Guests (See full list)
