Axle Seal
bradpell8
Well did my right front axle seal today. It was not bad at all real easy. I guess I was a little nervous after reading horror stories on some posts on here. Pretty self explanatory when I took the tube off the springs washer and 4wd coupling only go on one way if it is put together wrong i will not go together so I really do not know what I was worried about. Took about an hour but next time I bet I could cut that in half. Wish I had a lift though but not too bad doing it while on jack stands. Thanks guys for the help it is much appreciated. I am sure the LF seal would be a little harder but I think I would take the whole diff out and split the case. Not leaking now so if it is not broke do not fix it. :lol::)
removing the whole frt diff is not required to do the left frt seal,
those shafts sometimes fall out and other times not so easy on 3/4 tons especially,
glad ya got 'er
Left front is held in by an internal snap ring. Remove or reposition the left front axle and take a good swing with a hammer and the left front stub shaft should pop loose.
Thanks man appreciate it. Also thanks for the help in my prior post about a axle seal.
