Are All Gm 6 Lug Wheels The Same Bolt Pattern?
slowass95
Hi, Im new to this forum. I have a 95 k1500 4x4 and I want to get a set of wheels off of a newer pickup/tahoe etc. Will any gm 6 lug wheel fit my truck?
Thanks.
Hi... and welcome...
within the time span you are talking about ... yes the 6 lug wheels/rims have the same bolt pattern spacing from the 1995 k1500 4x4 to the newer trucks 2000 and newer 2wd or 4wd ....
the bolt spacing is the same... but I would check the diameter of the center hole just to be sure... I don't think there is a problem .. but you want to know before you buy them...
... this is likely not an issue for you... but there are some odd 6-bolt rims around that came off of 2wd LD2500 pickups and vans in the 88-98 years .. the bolt pattern is the same, but the rims are narrower and the offset is much different.
Cool.
Thanks. There are a lot of wheels to choose from on the local craigs list. I'm hoping to get something from a newer say 2000 on up. If I get a larger wheel (say a 17 inch) is it a lot of trouble to get the speedo corrected?
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 488 Guests (See full list)
