Ok I Am Rim And Tire Stupid...
BrpHauler
Looking at a set of American Racing Punishers 20x9.5 6mm offset. I assume I can fit these to my 2011 GMC Sierra? What brand and size of tire do you guys think I should run. I currently have stock suspension but am considering a RC 2" Leveling kit. I want a tire that looks semi agressive.
I would go with a a leveling kit and something close to a 33" I'm no expert on the 20" tire sizes so I'll leave that specific part to the experts.
The mickey thompson baja ATZ's are nice, but they are pretty pricey, also the the toyo open country M/T's are very nice as well. Not sure how aggressive you want to go though
You are going from what is likely stock offset of -31mm to 6mm so you have to know that your rims will stick out almost 1.5" more than they do now and the wider wheel will be about 2" likely.
Stock offset is +31 .. he wants to install a +6 so thats 25mm so just a little under 1 inch. Since the OEM wheels and tires are actually tucked in, these wheels will bring it closer to flush..(maybe stick out a tiny bit).
I am thinking you might be able to get away with 305/50/20's... It will be the most aggressive size you could go with.. There honestly arent that many other good sizing options for the 20 unless you wanna go down to a 275 width but thats not very aggressive its just about stock width. You might have to trim some plastic but you should be good to go with that size.
The cooper zeons in that tire size are trending right now as a nice tire for this application, i believe.
Thanks for the helpful information so far.
I guess the last question is would you guys recommend this particular offset or should I look for something else?
    scotthvac.net
    scotthvac.net
  • Who's Online   2 Members, 0 Anonymous, 381 Guests (See full list)
