Zone 1.5" Body Lift
So I would like to put a Zone 1.5" body lift but my truck is brand new so will it affected the warranty on the truck? Should I wait (a thing i'm not able to do normally) to put the kit??
It shouldn't void any warranty. If it does, they have to prove that it was caused from the body lift. Maybe if something odd messes up like the steering column (streched longer) etc... But if your ball joints or 4wd or something goes out, there is no way it was caused by the body lift. I doubt you would have any issues.
I just added mine a couple of weeks ago and the truck looks 1000 times better.
Also, if you don't mind that extra .25" or haven't bought the zone yet, I would look at the Rough County 1.25" BL (this wasn't available when I bought my zone). It is cheaper and looks easier to install because it comes with "new" front bumper brackets. That's is what takes so long on the zone is the front and rear brackets (cutting with a sawzall, and drilling). I would have maybe went that route, but I had already bought the zone. Don't get me wrong, I love the way the zone looks (maybe that .25" makes a difference), but the RC looks a little easier. Look at the zone instructions on the bumper brackets, and look at the picture of the RC body lift, and you will see what I'm talking about with the brackets.
Another option would be to have the dealer install it. It will cost you an arm and a leg for labor but usually they will warranty their work, which in turn will not void your factory warranty.
I installed mine with my uncle (mechanic) and it was very time consuming but not very difficult at all. In response to the warranty, I'm with Nick, they would have to prove the BL caused the failing part.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,262 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
