Lowering 3/4 Ton Truck Int Rear
Any body lower their truck to make it more usable. They have just gotten ricicuously hig the last few years. And please no young punks say they need to be that high to haul loads :) 20 years ago a 3/4 ton truck sat lower than todays half ton trucks :sigh: Don't get me wrong. I have a 1/2 ton I like to run round in that is stock high enough but for work I have a couple 3/4 tons and they are just too high, any body lowered one> I notice this shackle in back what if I removed it. It looks like it would drop truck 3" in back and I notice back is about 3 higher than front so I think it'd look ok? Thoughts comments welcome as always....
Actually, removing it would raise the back, you need a longer shackle and they make lowering shackles that would replace the stock one. Check companies like Belltech, DJM and McGaughys, they should have what you need.
I agree with you, I am planning on dropping mine in the rear soon and adding bags to retrain the load capacity. I am giving very serious thought to using the Firestone R4 tech kit which replaces the rear springs with bags, it even has a feature that lets all the air out and drops the rear for loading on and unloading.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 703 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
