Newbee Question On 87 1500 Ignition
hello I am more familiar with the earlier models but i have an 87 it gets spark while cranking it from coil to center plug on disributor bit no spark to plugs I put a complete brand new distributor in it but still nothing the fuel pump and injectors seem to be working ..I know the timing is right and thats where Im at right now but the truck is at least in a warm place I know i should not be just swapping parts to find the problem but if someone can tell me what to try next that would be great ..thanks in advance for any answers .. the truck is an 87 gmc 1500 overdrive 4x4 with the throttlebody
Replace the ignition module.located on the dis with the 2 wires connected to it.
Doesn;t it have an HEI?
  • 9 months later...
Check the cap. Bet the button in the center of the cap is missing. If it is there, the rotor button is bad. Check for carbon tracking.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
