2004 2500hd Lb7 Vin Check?
I am hoping that I could get a little advice from the group. I currently drive a '09 3500HD with the 6.0L/3.73 rear end and have found a 2004 2500HD with LB7 (85K miles and it is lifted). If someone has personal experience with the LB7 and a lift with 35's what sort of MPG could I expect. I love my '09 but the gas bill is killing me (ave 14.1 MPG over 65K all hand calculated). Also I would like an oil burner to pull a 5th wheel travel trailer in the near future. The gasser can only handle around 10K (staying w/in the design limits) and I plan on getting one a bit bigger.
If someone could run a VIN check that would be greatly appreciated. The VIN is 1GCHK23194F150916. My main concern is that the truck should be running out of the 7yr/200K injector replacement any time now. I do not want to pay for that out of pocket.
Thank you much for the help!
Thank you for the link. I was hoping that someone has access to the GM system to see if the injectors have been replaced.
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 1 Anonymous, 449 Guests (See full list)
