New Tire Guidance
centex
I have a 06 gmc sierra 1500 with stock chrome 17" rims currently with balding 265/70/17 pathfinders. I am looking at a more agressive tire between falken and nitto terra grapplers. I would like to go up to a 295/70/17 but don't kno if this would kill mpg or rub to much w/o lift kit. Any nitto between 265 and 295 is what im looking at, any advice on my next aggressive tire.
Thanks,
God Bless
I have done nothing in terms of leveling kit or anything, they are not stock tire, stock was 245/70/17, first pair of tires put on are the 265/70/17 pathfinders i have on now, as far as specs i dont know the detail as others give, its 6 lug if that helps.
I am just looking for a more aggressive tire for my truck, do you think Falken or nitto 265/70/17's would look decent on a 1500 or would i have to get bigger tire and lift kit for that look? Also you are advising to stick to 265 because bigger tire will cause too much rubbing w/o lift?
285/70r17 fit great on your body style. You can prolly clear the 295s too, if they rub then crank your torison bars a couple of turns.
I would reccomend the terra grappler, or trail if you want a more aggressive tire, as well as the Toyo AT and MT's, also the cooper zeon's are definately worth checking out as well if they come in your size.
    hotfish
    hotfish
  • Who's Online   5 Members, 0 Anonymous, 815 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
