Rear Sway Bar
I was thinking of putting an Addco rear sway bar in my 99 truck.  For $125, I thought it would be a good investment.  Anyone ever try one?  Are they hard to put in?  Did they make a big improvement?  I drive a dirt road alot and I'm trying to eliminate or minimize rear wheel hop.  Going to the 99 1/2 ton from a 93 Ford F-250 made a big improvement already.  I was just wondering if I can make it better.
I've got the Hellwig kits front and rear.  They make a huge difference in cornering, without sacrificing ride quality.  I lose some off road ability with stiffened suspension, but....
I put on the Hellwig rear anti-sway bar kit about five months ago - noticed a tremendous difference.  I never complained about the cornering ability before, but it got a lot better after the bar went on.  Those good poly bushings help too.  Only complaint I have about the Hellwig product is that the hardware seems a bit cheap.  The brackets that go on the rear axle and the upper frame member clearly will accept a larger diameter u-bolt, but the ones that come with the kit are a little light: 3/8", if I recall correctly. Still, it seems to be solid enough, but I hope to find the time to swap in some beefier u-bolts before next spring.
They say you shouldn't do any serious off-roading with a anti-sway bar on, and I can believe it.  The assembly that clamps onto the axle is just asking to snag on something - the lower part of the bar, too.
Got mine from Summit Racing: $129.95 or thereabouts.  EXCELLENT service from the folks at Summit, bythe way.  Very reasonable shipping charges, considering the weight of the units.
2002 1500 Ext. 4x4 5.3 Locker
I put the Hellwig sway bar on the rear of mine also. It made a big improvement in handling. It also helped with sway on pulling the Travel Trailer. Mine came from Summit, I was quoted $229.00 in town and got it for $129.95 at Summit Racing.
    MANGOAL
    MANGOAL
  • Who's Online   1 Member, 0 Anonymous, 482 Guests (See full list)
