IRL Wreck
Elwood
Did anyone see the wreck in the IRL race in Australia today?
Happened right at the start of the race.
Why do they race in the rain, when they know this stuff is going to be the result?
It was a nine car accident that happened because they rain made the track slick, and the spray from the tires made it impossible to see.  It looked pretty nasty.  I saw it on Sportscenter, and then I just watched the beginning of the replay of the race on SPEED.
It was CART instead of IRL, but same thing though.  :)
That whole race seemed to be a big mess.  And people complain about how NASCAR finishes some of it's races.  :chevy:
I see.  I don't keep up with that stuff at all, and I figured since it was called the INDY 300, but was not in Indy it must be IRL.  Oh well, either way IMO it was an unnecessary accident.
I'll just add this to the list as another reason I don't watch these series.   :chevy:
True race cars are open-wheel cars... Stupid accident yes, but at least its not as often as NASCAR and at least theres an excuse... NASCAR guys fu*k up constantly in perfect conditions... Real talent is shown in open wheel cars... A nice demolition derby could be seen watching NASCAR drivers run IRL/ champ-cars... (Tony Stewart being the exception there)
A race car is a race car, regardless of if it is open-wheeled or not.  I seriously doubt that one or the other takes more skill to drive then any other type of car.  Heck, just look at how well most of the open wheel drivers do when they try to drive a full-bodied stock car.  :cheers:  You can't tell me that it is simple to drive a car that weighs twice as much yet only has half the contact patch area of an indy car.  I doubt there are more then a handfull of guys in either series that could drive in both and win.
Now don't get me wrong about the IRL.  With the way their rules are setup, they probably put on the best oval track racing in the country.  And it is a shame that people don't watch it, simply because they don't like open wheel racing.  But it is far from the only type of true race car out there.
Real open wheel cars either have, or don't have wings on the roof, have 800hp motors and slide sideways on dirt ovals :cheers:  :eek:
And the IRL does put on a good show. And I love to watch it. CART on the other hand, I havn't watched in years. I got tired of seeing all the rc's being integrated in and having to watch nose to tail racing. CART is killing itself with poor managment, and by trying to turn itself into a baby F-1.
    C. Hart
    C. Hart
  • Who's Online   2 Members, 1 Anonymous, 622 Guests (See full list)
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
