Interesting accident today
General Lee 01
Mother and I were driving down a highway today.
We come up this hill where it's about to crest and they have these construction signs that say right shoulder closed ahead.
We get over the top of the hill, there's all these emergency vehicles and tow trucks  surrounding this Semi-Truck & Trailer.
We get closer, we seee that the front end of the trailer doesn't look right. (####, from our angle, getting closer, we were afraid what the truuck was gonna look like!).
And we get there, and my jaw dropped when I realized what happened.
A point on the trailer just behind where the support legs (What the front of the trailer sits on when they disconnect the truck & Trailer) on the Trailer "Buckled", and collapsed to the ground, making the trailer look like a big check mark. I was surprised to see the truck looked noone the worse for the wear.
Wish I could have gotten some pics for you guys.
The trailer was one of those types they fill up with mulch or wood chips and haul somewhere (I presume a mulch packaging plant or somewhere like that).
I have questions for those who are familiar with the Trucking industry.
Does this type of thing happen often?
Could the weather have played a part in this? (It was raining cats and Dogs all day today)
Improper loading, such as in this one.  These trailers aren't meant to haul loads such as grain, this is the result.
Or, in the case of this truck, but not in the case you saw, problems while unloading, all this came flying back and shifted the weight too fast for the frame to handle.
This is almost identical to what I saw, except the stuff inside (remarkably) stayed inside the trailer i saw.
And that's the same type of trailer too.
JP,
 That trailer isnt even a grain hopper.  Its a plain old dry van trailer.  I think the owner/driver of that setup ranks up there with the retard that cant spell Chevrolet!
We had a driver at work that decided he didnt want to make sure he was hooked to his trailer.  Needless to say as he was flying across the parking lot to leave, he lost his trailer loaded with 35000 lbs worth of meat.  It folded the dolly legs under the trailer, tore off a bunch of crossmembers and smashed the reefer fuel tank.  So much for a brand new trailer!
The way it shouldnt look....
The way it should look!!
Did it look like a well built aluminum chip van trailer? Or did it look like somoen gutted out an old refrigerated trailer and threw a gate on the back? Some guys do that down here for cheap sugarcane trailers, but the trailers can't handle the load. Need a good chip van, or walking floor trailer to handle that kinda stuff. My father does contract hauling for Martco, and we have a 23 ton minimum on Chip mulch or chips for loads. I've seen a couple of other trucking companys use cheapo trailers with the same results.
99Silver5.3 I didn't know you where with Trans Am. You guys have some great looking equip. and I'm sure they're set up to run. I came real close to putting my app. in down there in Springfield before I quit driving full time.
I've seen a lot of that kinda stuff happen  :cheers:  As soon as I get a scanner I'll show you guy's a pic of a who was working as a "spotter" at this company I drove for. He flipped a pnuematic trailer over full of crushed limestone on a flat concrete parking lot. Tractor and all :)
Theres another genius at work!   :)  Everything is nice but the old high-mile Freightliner Century's.  They are turning into some oil leaking bastards!  Do you live in Missouri??
Theres another genius at work!   :(  Everything is nice but the old high-mile Freightliner Century's.  They are turning into some oil leaking bastards!  Do you live in Missouri??
No. West Central Il. I guess you could say the intersection of I72 and HWY 107. Griggsville.
    C. Hart
    C. Hart
  • Who's Online   4 Members, 0 Anonymous, 526 Guests (See full list)
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
