Temp For Clay Bar
I am on vacation this upcoming week and would like to clay bar my truck and get the dreadful process over. I live in upstate ny and temps are not spring like to say the least. Does anyone know if there is a minimum temp. it must be to use the clay bar effectively? Thanks for your help in advance
    bellssn690
    bellssn690
  • Who's Online   5 Members, 1 Anonymous, 1,102 Guests (See full list)
