2 Question Relating To The 2011 2500hd 6.0l Gas Model.
JLeosnow
I know.... I should know these answers but cant seem to find a solid answer in any of the Chevrolet information. I figured I would get more accurate infomation from the board members here vs. asking the dealer so here goes....
1) Do the gas engine models have the grade braking feature or is it only the diesel models?
2) I thought I read somewhere that the factory brake controller is fully integraded with the vehicles ABS system. Does this mean that when a trailer with electric brakes is hooked up to the truck the ABS function of the truck also transfers to the trailer creating ABS for the trailer brakes?
Thanks much,
-John
Wouldn't each of your trailer wheels need to have a VSS (vehicle speed sensor) to have ABS? My understanding of ABS is that the computer tracks the reported speed of your wheels through the VSS sensors in your hubs and pulses the brakes on the individual wheels when it senses the wheel is not rotating. That is why you get an ABS/traction light when your VSS sensors go out. I would almost guarantee that your trailer brakes don't have "ABS" or pulse when your truck is skidding. There is no "signal" wire from your trailer hubs/brakes anyway. The brake pin is just a wire that powers your trailer brakes.
d/l the manual here.....
http://www.gmc.com/content/dam/GMC/global/...erra-manual.pdf
Trailer Sway
Control (TSC)
Trailer Sway Control (TSC)
2500 and 3500 series vehicles with
StabiliTrak have a Trailer Sway
Control (TSC) feature. If the vehicle
is towing a trailer and the system
detects that the trailer is swaying,
the vehicle's brakes are applied
without the driver pressing the brake
pedal. If the vehicle is equipped with
the Integrated Trailer Brake Control
(ITBC) system, StabiliTrak may also
apply the trailer brakes. The TCS/
StabiliTrak warning light will flash on
the instrument panel cluster to notify
the driver to reduce speed. If the
trailer continues to sway, StabiliTrak
will reduce engine torque to help
slow the vehicle.
the 6L90E gears down on its own when decending a hill, just like the Alison. It does not have an exhaust brake like the Dmax, because it relies on vacuum to provide the 'reverse' torque. Diesels are unthrottled and require the exhaust restriction to provide hold-back
This quote from the manual actually answers the question:
The ITBC system is integrated with the vehicle’s brake, antilock brake, and StabiliTrak (if equipped) systems. In trailering conditions that cause the vehicle’s antilock brake or StabiliTrak systems to activate, power sent to the trailer's brakes will be automatically adjusted to minimize trailer wheel lock-up. This does not imply that the trailer has StabiliTrak.
The system cannot detect if the trailer wheels have locked up. It only cuts braking power if the vehicle is skidding.
Exactly, it reacts to what the truck wheels are doing and adjusts the trailer brake power accordingly. So No you don't technically have ABS in the trailer, but a simulated ABS :lol:
Answer: Gas trucks are the same other then the engine. I had my 2009 2500 HD in for inspection recently and from the size of those calipers along with the hydraulic assist they now use, this truck can stop a train!
Answer: As stated already ABS will NOT work with your trailer brakes. The trailer braking system does however sense the amount of pressure you apply to the brake pedal and ramps up the voltage to the trailer brakes the harder you push down on the pedal.
I believe these new brakes could stop a train!! This truck brakes better than any other truck I've ever driven.
This is what I am hoping for Stevens11. Obviosly the trailer does not have ABS but am hoping that the brake controller will duplicate the truck's brake pattern back to the trailer brakes when applied/mashing the brakes...
Thanks,
-John
phillyturbosix,
It has been my understanding that this the normal operation of any brake controller, built in to the vehicle from the manufacturer or an aftermarket controller. I may be wrong....?
Thanks,
-John
phillyturbosix,
Thanks,
-John
Well you might find some old trailers that don't react that way but anything newer should work like that. It's just voltage being applied to the magnets that push out the brakes. The harder you push the more voltage is sent to the trailer brakes. At least you hope it's working that way! :)
the 2011HD brakes can stop a train the years under that can only stop a bus :lol:. I never had any truck that stops rides and carries loads as well as the new 2011HD
    • New to this forum.  Also looking to tune a 6L80 and trying to work out all the issues in my transmission swap.  I have a 6.2 diesel (1983) and have removed the TH-400 and about to put in a 6L80 with a TCM-2600 interface and don't have a clue what I doing after that.  Did you (Leatherneck/RAV3) get your slip resolved? I too hate to spend that kind of money on a tuner that hopefully I will not need too many times although from what steelerdude15 added about the HP Tuner being great for diagnostics would be a plus.  I am also from WNC but below you in Columbus.  Any helo would be greatly appreciated.
    • Sounds like a smart reasonable person with common sense. Bill O’Riley never said he was just a journalist, by the way.
    • It's like saying Bill O'Reilly is "just" a journalist.         Lauren Fix, widely known as "The Car Coach," is a prominent automotive journalist, television personality, and self-identified conservative. She is a frequent contributor to right-leaning networks and platforms, offering commentary that intersects the automotive industry, consumer economics, and conservative political perspectives. [1, 2, 3] Media and Commentary Network Contributions: Fix serves as the National Automotive Correspondent for Newsmax and is a frequent guest on Fox News and Fox Business. Video Platforms: She has contributed to PragerU, where she has hosted videos critiquing government mandates on vehicles. [1, 2, 3] Core Positions Anti-EV Mandates & Fuel Policies: Fix regularly critiques government subsidies and mandates for electric vehicles (EVs), framing them as impractical and burdensome to the average consumer. She advocates for consumer choice and supports traditional internal combustion engine vehicles. [1, 2, 3] Economic Analysis: Her commentary often emphasizes the impacts of fuel prices, inflation, and federal regulations on drivers. [1, 2, 3] Political Alignment: On her public channels, she actively supports deregulation, "drill baby drill" energy policies, and the removal of government restrictions on auto sales and manufacturing. [1, 2] For analysis from Lauren Fix on how consumer automotive choices can align with political leanings:
    • Wouldn't swapping out the original AFM/DFM parts for a complete Delete Kit be the best route to go if one could afford to go that route?
    • It comes with directions but yes, generally, it's the same.  Also, get you the dipstick stuff to install dipstick so you have one.
