Keyless Entry Possible?
lowrider
I just got a 2011 Silverado WT with the LS package - Regular Cab, Long Bed. It has the SEO package (power windows, locks, and mirrors) which includes 5B5 and AU3. Can a vehicle with these codes be programmed for keyless entry? If the VIN will help it's 1GCNCPEA8BF136108. If possible, what should it cost? Thanks.
Lou
No Responses :shakehead: All the dealers I called said it can't be done. Somehow I just don't believe them, but, I'll be going with an aftermarket solution. Why anyone automotive builder would build a vehicle with power door locks and no keyless entry is beyond me :lol::troll::flag::flag::flag:
Lou
Yes, It is possible . :dunno:
PIT4560D RKE Inoperative Unable To Program Fobs
The following diagnosis might be helpful if the vehicle
exhibits the symptom(s) described in this PI.
Condition/Concern:
Technicians may be unable to program the key fobs to
the vehicle. The Tech 2 may display the following
message when trying to enter the programming mode:
²Device Control Not Allowed². When reviewing the
options for the vehicle in GM VIS it may be noticed that
the vehicle is equipped with RPO AU3 - ²POWER
DOOR LOCKS WITH REMOTE KEYLESS ENTRY².
RPO AU3 does not include Remote Keyless Entry if the
vehicle is also equipped with RPO 5B5. This information
is listed in the ordering guide and has been provided
below. The vehicle would have needed to be ordered
with optional RPO AU0 for it to have Remote
Keyless Entry.
OrderGuideInformation below:
AU3 Power Door Locks
- Standard on Crew Cab models. Includes (AU0)
Remote Keyless Entry unless SEO (5B5) power
windows, locks and mirrors are ordered.
5B5 Power Windows, locks and mirrors, with up level
door panels on a base trim level vehicle.
- Provides power driver and passenger front side
windows with up level door panels on a base level
vehicle. Includes RPO (DL8) outside heated power-
adjustable manual folding mirrors, RPO (AU3) power
door locks and RPO (UQ3) speaker system audio
system feature. C/K***43-53 models include rear door
power windows and locks. Power mirrors can be
upgraded to SEO (6P3) camper, power-adjustable
glass, and manual extendable, heated mirrors. (RPO
AU0 Remote Keyless Entry becomes optional on all
models and must be ordered and priced if desired.)
AU0 Remote Keyless Entry, with 2 transmitters, panic
button and content theft alarm
- Optional on all models when SEO (5B5) power
windows, locks and mirrors is ordered requires SEO
(5B5) power windows, locks and mirrors
Recommendation/Instructions:
The vehicle is built as intended. If the RKE option would
like to be added contact the Techline Customer Support
Center @ 800-828-6860 to obtain calibrations.
Please follow this diagnostic or repair process
thoroughly and complete each step. If the condition
exhibited is resolved without completing every step, the
remaining steps do not need to be performed.
File In Section: Service Bulletin
Bulletin No.: PIT4560D
Date: June, 2010
C
  • 5 months later...
lowrider: did you ever get this installed? I have 09 silverado ls with au3 and 5b5 and was wondering how much this option cost to add. Thanks.
^^^^ Yes, I had my local electronics store add an Auto Page system. The most expensive part of the system was the interface module to the GM system. It cost more than the security system module. Anyway my system with three remotes, tax and labor to install came to $227.69. I like the system a lot. One of it's features is if you lock the doors with the remote and try to unlock with the key or the buttons on the doors it sets off the alarm (horn starts honking). Also I can unlock only one door or both doors from the fob. Again, I like it.
Also, the tech that installed it, did not look at any instructions. It appeared he had done this many times before. It took him less than 20 mins.
Lou
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 506 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
