checking tranny fluid
I have a 95 z71 with 350 and auto (4L60E).
I changed the trans fluid and filter today just as I have many times before on other vehicles. My problem is getting a accurate fluid level reading. I go through the entire process listed in the owners manual and something wierd happens. When it comes time in the process to pull the dipstick out of the tube the level is perfect. BUT the procedure says to wipe the dipstick clean and re-insert. When I pull it back out the fluid level looks about 2" above the max
mark. According to my manual it says to refill with five quarts when doing a fluid/filter change. I did just that. Removed pan, draned fluid, installed new filter, and refilled with 5 qts. So what gives?
Once again when I pull the dipstick out the first time the level is perfect. When I wipe it clean, reinsert, and check the level it is about 2" higher?
Maybe when I pull the dipstick out it "vents" the system and causes fluid level in the pan to rise?
I have also heard on the net that the fluid level in certain trannys should be about 2" over the full mark. Is the 4L60E one of them?
Thanks
I've had similar problems like that in the past with an old toyota we once had.  What I started doing was getting a one gallon milk jug and emptying the old fluid into those before I started adding new fluid.  This way I knew how much came out and how much to expect to put back in. :thumb:
I know what you are talking about though just when you think you have a good reading it looks like it may be overfilled.   ???
