Been in a baffle with two different styles, the black ones or the chrome ones, the black look pretty awesome and the chrome do too just not sure what would look better, my truck is silver birch metallic with only chrome rims and bumpers everything else black including the bed cover. Anyone have the same setup wth either?
    Policeoff01
    Policeoff01
  • Who's Online   4 Members, 1 Anonymous, 771 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
