Factory Trans Temp Gauge Help
OK, I finally got all the parts together to install the factory style transmission temperature gauge into my cluster. I began putting all the pieces together, but I keep getting intermittent signls to the stepper motor. So I took it off thinking it was a a cold solder joint. But, I never did get a clear signal. The stepper motor would reset like all the other motors, but I nver could get it to move as the truck heated up. So, I tried and trid again, and now my circuit board is looking pretty rough. Can someone help me to salvage the board? I dont want to keep trying and burn it up.
P.S. If I cant get it to work, Im gonna be putting it all up for sale. SO if anyone wants all the parts to do the swap, Ill sell them for $100 plus shipping.
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 501 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
