Rear Door Panel Rattle
Does anyone have this when they turn their music up? The bass makes them rattle a lot, and I checked the upper panel and it's fairly loose, I've checked other trucks and they're the same. If anyone else had this problem does anyone know a solution? I thought about using dynomat, didn't know if anyones tried that
that's funny , I had to p/u my truck from the dealer today after getting the driveshaft replace today and we where talking about this. they are going to look into this the next time my truck goes in.
I have put Velcro strips on the back of the pop up door lock so they don't rattle. Added Dynomat to the door frame and speaker adapter plates. Also added double side tape to the top of the door panel so it doesn't rub the door frame.
Thanks man, I'll probably try doing this I really dont want them tearing my truck apart I can see that making it worse. I'm assuming yours doesnt rattle now?
My 09 has rattled since day one just in other places, this just annoys me the most now. And I really wanted a sub but can't imagine what else will rattle with one...but thanks nadie I'm sure I'll be doing that soon
My Driver door did the same thing, I took the panel off and added a little duct tape to the plastic clips so the didn't move in the panel and I added some duct tape on the door panel where it would touch the door. That fixed the rattle for me. If I was upgrading my sound system I would use something like dynomat but for the stock stuff I just wanted the rattle gone.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
