Ladder Rack Help
I'm in the need of a ladder rack. I would use it for a ladder, kayak, wood, etc. I went to Harbor Freight and bought a Haul-Master. The mounting bracket would need to be permanently attached (bolted to the bed), and I would have to drill into the bed. Does anyone know of a kit that would utilize the stake pocket. I tried to google it, but not having luck. Maybe I'll return it, and try to find something else. I'm open to ideas.
Link to the ladder rack I bought:
http://www.harborfreight.com/250-lb-truck-...rack-66187.html
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,003 Guests (See full list)
