Towing Question   Into Needed
I am currently looking at a 1995 1500 Silverado ext cab. 2X4 auto trans. 5.0 L carberated V-8. I was wondering what the max towing capacity is of this truck? I looked in the owners manual but it doesn't list it. I need something that can tow a min of 5,000 lbs.
You may want to think about getting the 5.7 instead (rated at 225hp) the 5.0 is rated at 190hp I believe. Do you know what gearing the 95 has? You should be able to tow the 5000lbs with it, but I'm not sure what the rating is.
Something ain't adding up here.. a 95 2x4 with the auto and a Carb??? I'm almost postive that these trucks had EFI.  Anyways The truck could pull around 5,000lbs just not real fast which shouldn't be an issue anyways...
As far as the 5.0L I look at it this way.  If I want V-6 acceleration I'll buy the 4.3 and if I want V-8 gas mileage I'll buy the 5.7L...Basically I would go with the bada$$ 350 over the other two options if that is available to you...In my opinion.
Yeah thats what I thought too, but when I opend up the hood there was the carberator stairing me in the face :D
If stock should be TBI.
I've known someone whom consistently hauled a tandem axle horse trailer with two horses and gear (wasn't speedy, but without problems) with an 89 EXT long bed 5.0L TBI.  I don't know what the tongue weight was, but two horses alone would be close to 5000lbs.
If the truck is in great shape and costs very little, get it and run the 5.0L till death and then just replace with a 5.7L.  The tranny should be a 700R4...well 95 it's a 4L60...will need a cooler on it no matter what.
Axel ratio is going to matter a lot with the relatively low power of a TBI 305 (175 HP).
The relevent glovebox codes are:
GT4 = 3.73
GT5 = 4.10
Either of those will do nicely.  4.10 slightly preferred.
GU6 = 3.42 -- I would consider this marginal for towing 5,000#.
GU4 = 3.08 -- I would not tow 5,000# with it.
Of course all the standard recommendations apply...tranmission cooler, brake controller, weight distributing hitch...your mileage may vary.
    appletrav
    appletrav
  • Who's Online   1 Member, 1 Anonymous, 325 Guests (See full list)
