how much fluid is supposed to go in the front and back diff. I know its supposed to be a little below the hole but about how much fluid is that? The front diff is supposed to have 80w-90 but can i put the 75w-90 synthetic in the front?Whats the trick to getting the spare tire to come off i cant get the secondary latch to let go and now i cant get the cable to raise and tighten the tire back up.
75W-90 is fine for both.
2007 CHEVROLET TRUCKS SILVERADO 1500 PICKUP 5.3L 8-cyl Engine Code [M]
LUBRICANTS & FLUIDS:
Engine Oil
Grade 1......API*[1]
Maximum Performance Signature Series 100% Synthetic 0W-30 Motor Oil (AZOQT)
Maximum Performance SAE 5W-30 Synthetic Motor Oil (ASLQT)
Performance Plus XL 5W-30 Synthetic Motor Oil (XLFQT)
Performance Synthetic 5W30 OE Motor Oil (OEFQT) All TEMPS......5W-30 [2]
Below -20 F......0W-30
Automatic Transmission,4L60-E......AF6
Low Viscosity Synthetic ATF (ATLQT)
Automatic Transmission,4L70-E......AF6
Standard Differential, Front 4WD 8.25 Axle......GL-5
All TEMPS......80W-90 [3]
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
Standard Differential, Rear......GL-5
All TEMPS......75W-90 [4]
Transfer Case,......AF6
Fluids
Power Steering Fluid......PS
Power Steering Fluid (PSFCN)
Brake Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN)
Clutch Fluid......
[1] Oil must be formulated to meet GM standard GM6094M.
[2] SAE 5W-30 is preferred.
[3] GM Part No US 89021671 Canada 89021672
[4] Synthetic axle lubricant GM Part no. 89021677 / Canada
89021678 formulated to meet GM Specification 9986115.
CAPACITIES:
Engine, with filter..........6.1 quarts [1]
Cooling System, GMT900 With AT With Elect Fan Initial Fill..........16.9 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 4L60-E Initial Fill..........5 quarts
Automatic Transmission, 4L70-E Initial Fill..........5 quarts
Automatic Transmission, Total Fill
4 speed 4L70-E..........11.3 quarts
4 speed 4L60-E..........11.3 quarts
Differential, With 8.25 RingGear Front..........3 pints
Differential, With 9.25 RingGear Front..........3.6 pints
Differential, With 8.6 RingGear Rear..........4.3 pints
Differential, With 9.50 RingGear Rear..........5.5 pints
Transfer Case, RPO NP2..........4.1 pints [2]
Transfer Case, RPO NQG..........3.2 pints [2]
[1] After refill check oil level.
[2] Certain 2007 new body style Chevy Silverado and GMC Sierra
light duty pickups may indicate on the Service Parts ID
label (RPO label) that the vehicle is equipped with a RPO
NQG (MP1226) transfer case, however RPO NP2 (MVG261)
was installed instead. The NP2 transfer case can be
identified by a blue label on the lower portion of the case.
The capacities; are NP2 1.9 liters NQG 1.5 liters
quick tip.. loosen your fill plugs first.. :P it sucks finding out after you drained your diff, that the fill plugs are seized tight and you can't remove them.. :mad:
another tip..put some anti-seize compound on the plugs before installing them. makes life easier next time..
good luck
    Dom Colussi
    Dom Colussi
  • Who's Online   3 Members, 0 Anonymous, 551 Guests (See full list)
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
