A/c Question
Dano07
Not sure if i put this in the right area. This is not on a chevy truck, but it is still on a Chevy.
I havea 2002 Chevy venture 3.4L entended LS with 82,000 miles with rear Air/Heat. We were having problems with all the AC in the vehicle took it in and had the compressor, condensor, drier, seals, and expansion valve replaced. the front works like a champ. The back starts to cool and then gets warm and then hot. I was wondering what else it could be. The front blows cold all the time.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,058 Guests (See full list)
