Help with '93 4x4
A buddy of mine is having trouble with his truck.  It has the 350 V-8 with the throttle body.  His truck when he tries to start it will shoot a flames up out of the Air Cleaner (TBI).
When the truck does run it has a lot of black smoke coming out of the tail pipe.
Any ideas what could be causing this?  He's got fairly new plugs and stuff on there.
We just got it started.  The engine is making a hissing noise when not pressing the accelerator.  The noise seems to be coming from where the injectors are.  The engine when smoking is a blackish grey.
The timing sounds like it needs to be adjusted. Flames should not be shooting thru....try that first.
Black smoke could be a number of things, bad cat., carbon build-up, timing is off, etc.
The hissing at the injectors is just the air being sucked in to the carb.
    Selfman
    Selfman
  • Who's Online   3 Members, 0 Anonymous, 419 Guests (See full list)
