'99 Chevy Silverado Dash Lights?
Hey all, bought a chevy a few weeks ago. Trying to get all the bugs fixed. The dash lights and a/c control lights do not work. Makes it a pain to drive at night. I've searched several different forums with common problems like this, but there doesn't ever seem to be a solution. I've checked obvious fuses. Not sure what to look at next.
1999 chevy silverado new body style z71 ext cab 5.3 auto
Thanks,
Kyle
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 504 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
