Chevy 1500 Not Cranking
I have a 2000 chevy 1500 v6. truck will not crank. everything has power but the solonoid isnt firing starter. if i use a screwdriver to jump solonoid the starter will engage and motor will run. I tested the purple solonoid wire and it has no power when the key is fully engaged. I swapped the starter relay and still nothing. I bypassed the neutral safety switch under dash, yup, and checked the connections at the tranny, still nothing. checked all the ignition fuses under hood and all check out. how can you test the ignition switch without replacing it? any ideas please help.
Is the security light flashing in the dash? If so, you need to check your key and make sure it is still programmed on your truck.
unfortunately it doesnt have the security chip in the key and ignition. its a plain jane ole work truck. no frills chevy
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 506 Guests (See full list)
