Black Silverado Door Emblems
HEy all,
I just got a 2011 Silverado on sunday but im already got the bug do fix it up. Unfortunately i just started a new job and im short on time.
What i really want to do black out the bowties and emblems. I would like to black out the silverado emblems on the doors, cuz i just dont want to due the bowties and not the emblems. To do this do i need to buy a new set and then paint them, or buy a black set??? THey are are individually on there i just cant picture taking them all off and on looking perfect as i would want it to.....
Anyone seen a how to on this or seen where i can pick up some emblems? THanks for all the help,
Any recommendations on what to due to it...
I want to get wheels and tires, black 18' or 20' with 285's however do you think this is a good idea if i'm an auditor and travel frequently??? any helpful tips on gas milage??? and leveling kit
I have the bedrail gaurds but still need a bedliner...(hopefully this weekend i can get some goodies!!!))
Thanks all in advance!
PS loven the truck, its my first "cherry popped" haha
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 1 Anonymous, 652 Guests (See full list)
