Gauge Cluster Problem
The speedo, tach, and gauges are no longer working today. The driver information center does not work either. The turn signal indicator lights on the cluster and check engine light DO work.
The associated fuses for the cluster are good.
This is for a 2003 GMC Yukon SLT
What else can I check before taking it to the stealer?
Thanks.
Happened to me about 2 months ago. Pulled the battery cable for 5 minutes and everything worked after that. Has not re-occured, go figure. Could try that.
Had the same problem. The stepping motors in the dash have failed. If your truck has less than 70,000 miles, it is covered under warranty, contact your dealer. Mine wasn't, but there's a guy on ebay who will replace ALL the steppers for $90 round trip. You will have to remove the dash unit, but it is simple, and there is a video on u-tube that shows you how. If you can't find the info, let me know. :thumbs:
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,129 Guests (See full list)
