WTB  95-99 2dr tahoe or yukon
Arick
I see that you said under 60k, I have a 95 Tahoe LS 2-door indigo blue. It has 128k on it. I have put new shocks, exhaust and 285 tires on it. It has buckets and a 350 in it. I live in se wisc. The truck runs really good and is ready for winter. The only reason I am selling it is that I am going to take a demo now at work. $8400 OBO
It has the gray cloth interior. The body is very clean and is blue in color. There are a few small dings. It has some hand painted pinstriping on it. Email me at [email protected] and I will send you some pictures.
nick
  • 1 month later...
FYI
In Tucson at a used dealership  Drive Time  Ajo/Park
520/791-9005
99 white, looks like basic non LS nor LT trim/grill
Don't know mileage nor price.  Just remember seeing it while at lunch on 1/3 Friday.
  • 1 month later...
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 393 Guests (See full list)
    • 2013 5.3 still to this day calls for the PF48 filter.  Which as a 15psi bypass pressure.     There is a TSB, 17-NA-157 that talks about the PF-63 and PF-64 filters which have a higher bypass rating of 22psi.    TSB HERE - temp.xml   "Beginning in 2012, the oil pumps began to regulate main gallery feedback instead of pump out pressure. This means that the oil pump now does not begin to regulate until pressure is built up to the main gallery. This change reduces the amount of time it takes to provide oil to the engine bearing and lifters during extreme cold start conditions.  Main gallery feedback oil pump control systems are present on the following engine families which use Spin-on oil filters: Small Gas Engine (SGE), Large Gas Engine (LGE), High Feature (HFV6) Gen2 and Small Block Gen5 gasoline engines. These engines with the main gallery feedback oil pump control systems are factory built with an ACDelco® oil filters"   It also calls out what engines use those filters.  The gen 4 small blocks were not on that list (LMG, LC9, L9H, L92, L94, L20, L96).  Gen 5 small blocks use the higher pressure filter.
    • To me it honestly makes zero difference what filter you run. It's not a race engine, just a truck engine that's mostly bumming highways and it just needs a filter that filters oil.   The filter used to be a 7060 and the long version was a 7045. Now it's the newer updated filter that the K2XX trucks and newer run, the 100255 I believe if we are using napa numbers. Any of those filters is going to do the job.   I wouldn't overthink it, to me it makes no difference because those first filter numbers worked for 18+ years before the spec suddenly changed.
