4wd Needs Service On Traverse?
Question,
How often does the fluid need to be changed? Yesterday I took our 2009 AWD Traverse on for an oil change. They said there is a front axle seal with a slight leak. Which will be covered under warrenty. But also they say my fluid is due for a change. I have not checked the manual yet, but this seems odd to me. Any thoughts? This GM Dealer is close to my house and I've had warrenty work done by them. First time they have done routine maintenance for me. This service they are recommending seems odd to me at my mileage.
Thanks,
BJL
