Rough Idle, Tried Everything I Can Think Of, Please Help
Hey guys, I recently purchased a 2001 GMC Sierra 2500HD with the 6.0. It recently developed a rough idle, seems to be worse when car is heated up, and you can feel it shake a little and the rpm moves around like its mis-firing. It threw a code for the TPS after I checked the voltage going to it, not sure if its because I fiddled with it or if its bad so I replaced it. Have any of you ever had a problem with the harness going to the TPS? The truck idles right around 500 or so when in park or in drive with my foot on the brake, shouldn't the idle be higher? Here is what I have replaced:
New Wires
New Plugs
New Air Filter
New TPS (Throttle position sensor)
New PCV Valve
New IAC (Idle Air Control) Valve
Cleaned throttle body really good
What would be the next thing to check or replace?? I want to maybe clean the injectors next and replace the fuel filter. Has anyone had this problem, any help would be appreciated, I am getting pretty frustrated and are running out of things to replace! Thanks.
I had kind of the same thing recently, it turned out to be the fuel filter. Pretty cheap and easy thing to eliminate, after that I'd make sure the fuel pump is working properly.
i would do the fuel filter, and not worry about the injectors. Sounds like a vacuum leak or maybe the tps like you were talking about. the commanded rpm idle speed when warmed up is 525 rpm. check the vacuum line going to the fuel pressure regulator, and when you take the vacuum line off the fpr make sure no fuel comes out of the vacuum side. i have seen this happen a lot when the fpr goes bad.
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
