HELP!
DuckhunterInTN
I have a 2000 Silverado extended cab Z71. Whenever I come up to a stop and the nose of the truck dives my truck makes a weird creaking sound. Its not a pop, but more of a "wiggit..wiggit" or something. It sounds like it is coming from the drivers side footwell. It sounds like it is coming from inside the truck, but it is hard to tell. I have hosed down everything (inside and out of the truck) I could think of with lubricant. Does ANYONE have any suggestions for anywhere else to look...I am at my wits end!
I have just spent the weekend chasing down that same issue.  I think I have isolated the source.  On mine, it was from the weatherstrip.  I used silicone dielectric grease and lubed all of the weatherstrip sealing the driver's door.  Where I found (knock on wood) the noise was the weatherstrip on the 4 th door (behind the driver's door) was squeaking against the interior door panel and the channel the weatherstrip attaches.  I pulled the strip out and lubed it well (complete weatherstrip especially inside the channel and where it comes into contact with the rear door panel).  So far, the noise seems to be gone.
JonesNTN,
 I called myself checking the door but am not entirely sure that is not the problem.  The door does make a creaking sound from the center hinge thing but I don't really thing that is the problem
Carguru,
 I put grease on all of my weather stripping but could have definately missed some spots.  It sounds like your noise was coming from behind you, right?  Mine seems to sound like it is coming from down around the driver's feet, almost behind the dash.
is it a creaking or a thud?
I have an occasional thud when making right turns that sounds like it is right under my feet
You might want to check your body mount bolts.  Theres one in that area.  After I put my step rails on, mine creaked after a while.  I tightened them up a time or two, but it kept coming back after a couple weeks, until I put some locktite on the threads.  :thumb:   Just a thought.
I thought about that.  I made sure they were tight with my hands but I don't really guess that is a very good indicator.  Where yours tight enough so that you could hand turn them but still loose enough to creak?
A couple just barely moved, but one or two moved about 1/8 of a turn.  I used a 1/2 inch drive ratchet to tighten them.  Couldn't move them by hand.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 338 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
