Remote Starter Not Working
akkeith
The remote start on my 2010 GMC 2500HD does not work. The doors lock and unlock with the fob but nothing happens when the start button is pressed. It worked the previous day. There are no codes present and remote start is turned on in the DIC. Looked for a specific fuse but did not see one just for the remote system. Any help would be greatly appreciated as the closest dealer is over 300 miles away.
well couple of things, since you didn't give a lot of info:
you have to press the lock button first, then the remote start within 10 seconds (pressing only the remote start button will not make it work).
you can only remote start 2 times then you have to use the key once. (some kind of safety feature).
remote start will not work if the hood is open.
remote start will not work if the 4-way hazards are on.
remote start will not work, or will turn off if the vehicle PCM detects low oil pressure or high coolant temp.
lastly the system can be disabled via the DIC, have you checked to be sure it is turned on there? (may have been accidently turned off)
I have used the remote succesfully before so none of the obvious things are the problem.
And as stated the remote is turned on in the DIC.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
