2002 Silverado Electrical Problems
sodell
I have a 2002 Silverado regular cab with a 5.3L, auto, 4X4. Everything was fine on the truck and then I parked it for a couple of months. When I went to start the truck I noticed that the battery was dead. I then tried to jump start it. I got it started but noticed that the alternator was not charging the battery. At the same time I kept hearing a popping sound coming from the radio and I had 3 lights in the message center. (battery, security, and ABS). I bought a rebuilt alternator and installed it. This fixed the charging issue. I also removed the radio and put my original factory radio back in. (The radio that was making the popping noise was a factory one but I got it from a junk yard because it had a CD player. It worked fine in the truck for over a year before this happened.) With the original radio and rebuilt alternator, I still have the security light, battery light, and abs light. I found that the light in the message center never turns off and it drains my battery so I have been pulling the radio fuse when I park so I don't drain the battery. Also after ~30min the BCM is still drawing a current with the key off. AlsoI tried connecting an OTC scan tool but could not communicate with anything. I checked the power and grounds at the DLC and the BCM and they are all working. I even pulled the splice out and tried communicating with on the BCM with a jumper wire between the DLC and the BCM with still no communication. I believe I know why the battery light is on but I'm not sure if that is causing everything else. With the rebuilt alternator, I am getting positive voltage at pins 1 and 2 of the 4 pin plug, however my truck has wires on pins 2 and 3. I am taking the truck back to the alternator rebuild shop to get it fixed but I don't think that is the only thing wrong. If anyone has any ideas where to look to next, the help would be much appreciated.
Shawn
After taking the alternator back and getting a different one. I am seeing a voltage on pins A, and C of the alternator while the engine is running. There is nothing on the wiring harness side of pin A. Pin C is the duty cycle signal and pin B is the voltage signal. I am getting 0V out of pin B. Is this supposed to be 0, +5V, or +12V while the alternator is running?
Thanks
Shawn
I used a scan tool to pull module by module and found that I can communicate with the BCM with the connectors pulled from the ECM. However, if I pull the BCM, I cannot communicate with the ECM. With both connected I cannot communicate with either one.
  • 3 months later...
    blueskytruc
    blueskytruc
  • Who's Online   3 Members, 0 Anonymous, 618 Guests (See full list)
