Led Tailgate Bar
So im looking into getting a Fire and Ice tailgate bar or a GORecon bar, haven't decided which one yet but there both pretty much the same. Anyway my question is, is there a way to make it plug and play with my 7-pin adapter on the back of my sierra. I really don't want to splice wires, was hoping there was an adapter or something i could buy to make it an easy plug and play and hide it behind my bumper. All the led bars are wired for 4-pin.
I have a custom dynamics lightbar. Very bright and far more LED's then Recon. What you can do is a "T" harness from Reese. The "T" harness pulgs in line under your truck behind the 7 pin and will give you a hidden 4 pin under your truck to plug the lightbar into. This also keeps the 7 pin open for towing.
Thanks man thats exactly what i need, ill check out that bar you said you have to. The more LED's the better.
I've got the Fire & Ice bar, and like nick3941sd mentioned, the T-connector is the way to go. I've got 3 or 4 of the clear LEDs on mine flickering when the truck is put in reverse or whenever the doors are locked using the key fob (the reverse lights come on when the doors are locked with the key fob). I am about to send the bar back to Plasmaglow, so I'll see exactly if their "lifetime warranty" will cover it or not.
I have the Custom dynamics light bar too and WOW what a difference over the recon. :P
    KirbyCo
    KirbyCo
  • Who's Online   1 Member, 0 Anonymous, 1,007 Guests (See full list)
