No Choice Of Wheel Size
Snappy comebacks but not many answers. Car manufacturers are nickel and diming us with waste of time increases that are useless and not giving us any choice. If you want 16", 17", 18", 20" tires then you can buy them. 15" tires work fine and always have. Plus they're cheaper and it's not because of availability...it's because they use less material. You're letting car manufacturers tell you what to do AND with NO explanation. If the bigger tires are because of bigger brake rotors and drums for safety then all vehicles with smaller tires should be outlawed...since they're not safe. That explanation doesn't hold water either. It's car manufacturers sneakily stealing our money for something we don't need. If you don't mind the extra cash...then buy my tires.
I wouldnt say they "make me" do anything. Buy a new truck, take an old rear end out of an old chevy, "custom" fit early 90's knuckles on the front and put your 15's on the truck, your will have more money into that but if you keep the truck for 20 yrs you might make out. If you do not like the 17-20+ options available now then do not but one, but you really have no right to complain, you choose to buy or not. No one twists your arm to sign.... drive an 86 chevy with a tbi 350 getting 8-10 mpg and you can have your 15" wheels also.
Bigger wheels means bigger brakes and better cooler plain and simple. Im speaking to a 17" which is stock on new trucks. Anything bigger is in an option package and apparently you dont want anything over a basic truck motor, body, 4 wheels.
Your not buying bigger tires, your buying a tire of the same size for a bigger wheel. Also you must not understand what your eyes see..... a bigger wheel means less rubber. Again a 33" tire on a 15 compared to a 33" tire on a 17.... the 17(which your not paying extra for since its stock) use a hell of a lot less rubber.... HOW CAN YOU NOT SEE THAT?
Its also not that the vehicles with the smaller brakes are "not safe". The fact is they try to do more with less... In the economy materials are dimishing. So most brake systems are using less over all material and sometime the over all dimensions might be larger. Bigger brakes doesnt mean more material, just different compositions of materials. The larger wheels are not tight to the calipers and rotors so heat disapates faster. Maybe ive been around cars to long but thats just common sense.
The vehicles with the smaller less adequate brakes are just that. Less adaquate or less efficient. Greater stopping distances more drag on the motor powering the booster etc........(which apparently you wont understand)
I also checked several tires and you 30-40$ difference between a 15 and 16 is WRONG.... Example go to NTWONLINE.com and check out BFG(expensive brand) rugged trail ta's, its barely $10's a tire more moving up from 15 to 16's in a respective size. I looked at 31/1050/15 and 265/70/16 and another 10 (which is a total of 20 per tire) if you go to a 265/65/17 which is an odd ball tire. More common is 255/70/17 and its the same price as the 16" equivelant i said. This happens with many tire brands....
Your absolutley right that we don't "need" it. It they never changed and all vehicles were the same then their would be no problem maybe. However people like new and different. People make money inventing, customizing etc...
In all honesty, no matter what i say your not going to get it or understand. Your opinion was made up longer before you started this topic. Therefore I will leave it at this and do my best not to continue on the argument.
Its your choice to which vehicle your purchase and drive. If your worried over a couple hundred bucks max between a 15" and 17" wheel then you shouldn't be driving a truck. Trucks are expensive. Trade it in on a small car, get better mpg's, tires will be much much cheaper and may be a 15" wheel (since you like that size).
You cant put a 15" or 16" wheel on an nbs or nnbs truck without some sort of modification or special backspacing to the wheel . In turn, you are going to spend money (more than $100) to try and save at most $70-150 depending on the tire you chose. If you buy an obs your gonna spend more money in gas than you will EVER spend in tires...
I have to quit now.... to irritated by your stupid @$ theory.
Looks like you had trouble with math in high school.
You've got conspiracy issues man. Your explanation doesn't hold water. Manufacturers are customer driven and "most" people like the look of the bigger wheels and that's why they do it. If they didn't make vehicles people liked or wanted, they would be out of business real fast.
If you don't like the wheels on your truck, then go buy another vehicle that suites your taste. If you want to modify your current vehicle to fit 15" wheels, then go for it. Where there's a will, there's a way. But if your complaint is just because your cheap, then do it somewhere else.
Please explain how my math is wrong?
  • 1 month later...
:cheers:
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
