Brake Line Sizing Sae Or Din
I have a 2004 GMC 1500. The brakes lines are starting to look bad, can anyone tell me if GM used metric tube and nuts with the Bubble flare or the old standard 45 Degree double flare on SAE lines. I want to purchase a flare tool kit and some material to start changing these lines out, Think I may have access to a Scan tool to bleed the ABS, so I would like to do this one at home and not bring it to the dealer. Any help would be great.
All lines on my 03 silverado were rotten. I just finished the same job. 70 ft .250 tubing double flared,all new hoses,brake cables,pads rotors,calipers. Afew extra unions are needed in tight places.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 909 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
