Aftermarket Usb Drive Out There ?
:thumbs: is there anyone that can help me with find the optional kit that can help me add a usb drive to my factory radio ??? i have a 2003 chevy silverado 1500 hd model ... with onstar and xm radio built into the head unit... i know if i pull the factory unit out and replace it with a aftermarket one ill loose all that... wich i dont want... im looking for a wiring harness to help me add a usb drive to the factory radio.... if some one could point me in the right direction that would be great... thanks :)
I wanted the same thing for my truck, but unfortunately there is nothing like that for the pre-07 trucks unless you go aftermarket. There is the iSimple ISGM575, which adds iPod/iPhone integration and an auxiliary input.
I'm not familiar with the 2003 specifically but I know my buddies 2004 just needed some adapters to retain everything. My 2008 was the same way. Are you sure the XM and OnStar is actually built into the deck? This would be the first time I've seen that. You get an adapter to run the onstar and likely will be better off just getting an XM for whatever aftermarket deck you get. Either way you'll be much better off in the long run. If you haven't already checkout Crutchfield.com, they will tell you what you need.
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 458 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
