Button lights?
Can you tell if the functions are still working? It's probably something internal with the circuitry. You can pick up a new unit for around $80.
Where is the control for the output vents located on. If the control is on defrost, floor only, defrost & floor, or floor & head then the AC and recirc will NOT work. You need to have the control on Head for them to work.
Tom
Thanks Tom, I did try it in all locations and still nothing. The recirculate does work but no light on? My A/C does not work but I believe that is something else like low freon. My levers for that actuator have come off as you might have read in a previous post but that only controls the door.
           Any ideas ..send them in...Mike
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,113 Guests (See full list)
