Differences between 1500, 1500HD, 2500, & 2500HD?
Everyone knows you can get bigger and badder engines the further up the ladder you go.  And everyone knows that the option packaging (for interior
But I'm talking about the differences that don't really get advertised or broadcasted to the public.
For example:
As you move up the 'chain':
-Do they get faster or slower?
-Do they become more or less reliable?  Engines?  Transmissions?  etc...
-Do they ride rougher or smoother?
-Are all of their frame's hydroformed, or just the 1500?  And along the same lines, are does their overall chassis rigidity become stronger or weaker (obviously the frames don't get weaker, but the added weight can cause this net effect)?  Is it more or less durable?
-Do the interiors become more or less noisy?
-Do they sit up higher or lower?
etc, etc...
I think y'all get the direction of this thread- what are the differences, small and large, that you noticed as you compare the various models of Silverados and Sierras?
Hopefully this could be a very informative thread for all of us to learn something from. :thumb:
That's alot of questions... LOL!
The 1500 is it's own beast as is the 2500HD.  The 2500 and 1500HD share components between themselves.
The 1500 has a smaller frame and lighter suspension along with a smaller rearend and the 4L60E tranny.
The 1500HD and 2500 are uprgraded suspensions and the heavy duty 4L80E tranny.
The 2500HD has an upgraded frame, heavier suspension, and also the 4L80E tranny.
The motor choices in the 1500 range from the 4.3L v-6 up to the 5.3L V-8.
The 1500HD and the 2500 are only available with the 6.0L V-8.
The 2500HD motors start with the 6.0L V-8 and the bigblock 8.1L and Duramax diesel are available as options.
The 2500HD trucks sit higher than the rest of them.
The ride becomes progessively stiffer as you move into the trucks with the higher GVW's, although they aren't jarring like the older last generation trucks.
I'm guessing a 5.3L 1500 would be the quickest truck of the bunch, but it could possibly be beat by an 8.1L 2500HD.
If you're comparing capacity classes with other manufacturers:
Chevy/GMC 1500s are 1/2 tons as are Ford F150 and Dodge Ram 1500s.
Chevy/GMC 1500HD and 2500 are 3/4 tons as are Ford F250 Superduty and Dodge Ram 2500.
Chevy/GMC 2500HD and 3500s are 1 tons as are Ford F350 Superduty and Dodge 3500s.
GM's 2500HD is really a single rear wheel 1 ton in the same essential towing and hauling class as the F350 and Ram 3500 single-rear wheels.
Ford and now Dodge for 2003 make both single and dual rear wheel 1-ton class pickups but they call them the F350 and Ram 3500 for both configurations.
    MANGOAL
    MANGOAL
  • Who's Online   0 Members, 0 Anonymous, 409 Guests (See full list)
