chevy trucksTailgate hinge
Hi, I was wanting to know the deal about these tailgate hinges on 88-98 trucks. I have been reading a lot about them and can't seem to find what I want to know. My dads may need replacing soon so thats why I am wanting to know. Are they really welded on the tailgate? I know you have to take the bolt(s) out and then a lot of people have said that they wont budge after that. And they never say what they found out, like if they were welded on or not. Just wanting to know, someone has got to have the answer. Thanks
    hotfish
    hotfish
  • Who's Online   5 Members, 0 Anonymous, 815 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
