built rear-end cost?
I have a 09 sierra with 3.42's witch i just blew to peices. they say the rear ends of this truck will break stock much less with engine mods done. i am lookin into buyin a built rear-end anybody have any idea how much this usuallys runs? in price and where to?
Your a very repetitive poster, find gears that will match front and back diffs, take the truck to a very good mech, one who knows what they are doing, have them swap the gears, you will likely have a warranty, could range from 1500 to 3000 maybe, probablyy not so much but it all depends
You might see if you can pick up a 14 bolt from a 2500 chevy or GMC and swap it in?
Edit: what do you mean by built? a tougher rear end or just one with some lower gears in it?
Are you referring to the gov lock (G-80) differential going out? If so, yes it does happen frequently on the 1500s, there are a handful of folks on here who have had the same thing happen, including mine. With no abuse to the thing, just normal use in winter time. So far no issues with the G80 in my 2500. It cost me $1600 to have the gov lock rebuilt on my 99 1500 when it went out at about 75,000 miles or so.
Buddy of mine had a 2002 Yukon XL with the locker and his blew out also. He had it replaced with a eaton posi and he also had to replace an axle. I think it was around $2000. The eaton posi worked great!
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
