Transfer case trouble
Hi everyone. I have a 2001 Chevy 2500HD ext cab s/b 8.1 6spd manual with manual shift transfer case. Here's my problem: When I pull out and start going through the gears, the t-case sounds like its Getn stuck between 2wd and neutral. Makes a grinding noise. Seems to do it when shifting gears or coasting...especially in 5th or 6th gear....when its not under "load". The t-case is full of fluid. It has also done this while climbing a hill in 4low....was fine while I was giving it throttle but as soon as I let off the gas it popped out...."neutral"
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
