Front bumper swap?
I have a 2007 1500 Sierra NBS and i wanna replace the stock front chrome bumper with one from a '09-12' Sierra with the cut out in the front. are these 2 a direct replacement? or do they not fit the same? does anyone have one?
Thanks,
Chris
It was listed for all Denali's, just ordered the Denali beceause I wanted a painted bumper. I would say any of those chrome ones would bolt right on.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,035 Guests (See full list)
