Need a tune if you change tire diameters
I know you would need a tune to bring the speedometer in correctly. But assuming you don't tune for the different tire diameters, leaving the speedometer incorrect, would the shift rpm remain the same? This would be a one time change maybe at the track just to see what the truck will do with traction and an equivalent lower gear. Not sure on the trucks where the ECM gets it reading for shifts.
I have some drag radials that are 25.4" in diameter, my truck has 29.84 diameter tires. These tires would give an equivalent 4.018 rear differential.
I'd say it would throw off not only your speedo but your shift points, and throw your ecm into a tizzy because nothings reading as it should. You would probably also trip your ABS :dunno:
Speedometer, ABS and TPM sensors would definitely go into a tizzy. That wouldn't have any bearing on power to the wheels. Not too sure about shift rpm. It should follow the speedometer making shift rpm the same even though not the correct speed. But I'm guessing. Just wonder if anyone has actually tried without a tune. Don't want to void this 5 year warranty. Not just yet anyway!
Nice looking Sierra you have. Had it to the track/dyno?
Thanks.. and no.. but some day hope to :thumbs:
    FiLo
    FiLo
  • Who's Online   5 Members, 0 Anonymous, 577 Guests (See full list)
